It is currently Tue Aug 12, 2025 6:01 am
PostPosted: Wed Jan 20, 2010 12:11 pm
First name: jack
Do any of you OLF'ers have photos of router jigs and/or setups that you use to inlay the guitar's end wedge that you wouldn't mind sharing?
best regards,
jack
PostPosted: Wed Jan 20, 2010 2:15 pm
I always hate it when people answer a question in a completely different direction... but... ;)
I used to use a router/jig, but just gave up and started using a backsaw. I have a template for the wedge and I use a marking knife to cut it out...
PostPosted: Wed Jan 20, 2010 2:17 pm
Backsaw and straightedge here. Flat file (the untapered kind) if the cut needs some adjusting. Individuals don't need to build like factories do.
PostPosted: Wed Jan 20, 2010 2:23 pm
First name: jack
I've been using a back saw, straight edge and chisel for over 25 years, so maybe I am doing something right;
Thanks for the replies,
jack
PostPosted: Wed Jan 20, 2010 2:37 pm
Same here - Japanese razor saw and straight edge + chisel
PostPosted: Wed Jan 20, 2010 2:39 pm
Sorry. nearly forgot - mark first with a knife japanese
PostPosted: Wed Jan 20, 2010 3:27 pm
Jig and laminate trimmer. Life's too short, more time for beer and friends.
PostPosted: Wed Jan 20, 2010 3:38 pm
Plexi template with centre line, 6" ruler with double side tape, dozuki saw and 1/4" chisel to remove the waste. It's a 5mn easy job.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Jan 20, 2010 4:15 pm
For years I scored with a marking knite, back sawed using a wood block as a guide, then routed out but any more I chisel out it is mich quicker and cleaner
PostPosted: Wed Jan 20, 2010 4:24 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
template from Mark Kett with lam trimmer. Reverse template and router table wedge itself. Quick & clean.
PostPosted: Wed Jan 20, 2010 4:56 pm
Here's how I do mine. By the time you set up a jig and router you could have the thing installed. I do mine by hand for that reason.
PostPosted: Wed Jan 20, 2010 5:33 pm
I just use a knife and a chisel. First, I use the knife to score the lines. I score them each 10 times or so, starting with very light passes and gradually increasing the pressure. From there, it's easy to remove the material with a chisel.
Once in a blue moon, I make a mistake, but they are always easily fixable -- nothing like the disasters I see people making when their routers go awry. And the knife/chisel approach makes the cut quicker than I can set up the router.
PostPosted: Wed Jan 20, 2010 5:44 pm
Users browsing this forum: modkev and 22 guests
